Coolermaster or FAR Case?
UnlimitedMP
Is it worth it to buy a $50 + tax ship Coolermaster case versus a Free After Rebate case that pops up at Fry's every now and then? (like the Wizard case).
The only thing I care about is function ... if it can fit the standard stuff + maybe an extra harddrive. It would not be moved much at all. There would be very mild to zero O/Cing.
if you don't care about looks at ALL? Go for the FAR one. *shrug* I had the chenbro case (original manufacturer) WAY back in the day, and the quality on it was pretty crappy. Small fans, door snapped off, etc.
For $35 after rebate, you can get the coolermaster Mistique (all aluminum if that matters, 2x 120mm fans, looks nice, etc) from SVC.com. And that Coolermaster Centurion 5 goes on sale there from time to time for $10 AR.
Outpost has ultra aluminus' dirt cheap, and they are good, light cases. get one of those.
It'll even fit an 8800GTX :)
