Coolermaster Haf X replacement fan
topslop1
I have a noisy bearing in the fan in my Coolermaster Haf X case.
It is the fan on the top of the case. I was wondering what fan I should order to replace it? And while I am at it I might as well order a second one for the blank spot next to it.
Which size and style fan would you recommend?
Don't need 150cfm. 80-80cfm is fine for a 20db fan. Thanks- I'll prolly grab the NZXT
+1 for the CM Megaflows. Had 4 of them in my HAF-X and they were great. The reviews speak for themselves. I've heard very mixed things about the NZXT's.
