fibroptikl
- Mar 9, 2000
I am looking for a new case to support an Extended ATX motherboard that I have.
I currently own an original CM Stacker that houses my server. While it's big - it holds everything in it, and has lots of room.
I was looking at the CM Stacker, and noticed there are several variations of it, including an CM Stacker 810.
I did a compare on CoolerMaster's website, but I can't find the differences between the CM Stacker and the CM Stacker. The one difference is the 810 weights 4.7kg less.
Anyone know the other differences?
