Coolermaster CM Stacker 832 Questions
fogzors
I'm looking at buying the Coolermaster CM Stacker 832 and i'm just curious if anyone has this case and what kind of fan setup do the run in the side. Is it possible to rig up four fans on a fan controller for there? Also I understand that the side fans are 140mm, anyone know of some reliable fan brands that are of that size?
I'm also looking to put a thermaltake ultra-120 extreme in there, will it fit?
http://www.ncix.com/products/index.php?sku=22231&vpn=RC-832-KKN1&manufacture=COOLERMASTER
I have the 830SE which is basically the same case with a different front cover and a few other small differences.
First off, the Ultra 120 Extreme will fit in the case (I have one myself, see sig) but you will not be able to use a fan on the upper left quadrant of the side fan case. So, at most, you'll be able to use three out of the four side fans.
I only use the bottom two spots there as I feel that is plenty. I have a combination of the CM 120mm blue LED and SilenX 120mm LED fans, both work well enough.
I don't use any 140mm fans or fan controllers so can't comment on those things.
Hope that helps.
Just got the case (got the $94 after MIR deal from newegg), and love it, ready to start filling it up.
Yate Loon makes good 140mm fans. You can find them at Jab-tech
