coolermaster aquagate vs koolance exos
xbreaka
Alright I want to go the watercooling route and iv pretty much decided i want a already put together system my question is mhz for mhz which one is better, i want to get some good numbers out of my 2400+ mobile, and if anyone could reccomend a good water block that would be kickass as well.
exos man. all the way. i have a P43.2c runs at 25C idle with the exos and the CPU200 waterblock i hit 4ghz no problem with only about 2 degree increase, maxes out at 33C under full load, plus i have 2HD coolers, one video and one northbridge cooler, and its still cool to the touch. i cant find a way i could ever overheat it
R1ckCa1n said:
Koolance everyday of the week when compared to a aquagate.
I second the above, you will be happy with the use of Koolance products, especially their most recent additions.
-Dan
I think you'll be happy with the EXOS, I know I sure am ! :)
Stick with the Koolance waterblocks, they seem to work better with the Koolance systems than the other "high performance" 1/2" tubing ones ! :)
exos
i run a p4c 2.4@3.4, radeon 9800pro@405mhz, and nb@1140fsb all on the same loop.
Exos is super quiet. The triple fans makes all the difference. The exos is a way easy to setup package. Very easy to fill and bleed and has dual pumps. 3/8 OD hosing is the only setback to Koolance. Get the 300wat CPU300 cooler and make sure you choose if you want the vertical fitting or horizontal. Of course I didnt and got the horizontal. =[
