I am going to be build an A64 system in a CoolerMaster case. I had a couple of question
1. How much room is there between the CoolerMaster mobo tray and the back of the case? I wanted to run some cables behind the tray but wasn't sure is there would be enough room. Has anyone done this (pics would be great).
2. General cabling question... Do they sell extensions to every type of cable? From the looks of it you would need much longer cables to run them behind the mobo tray.
3. Anyone have any good cabling "how-to" links or suggestions/tips?
Thanks.
Thanks.
