I've got a Beantech Igloo 10 case here. So far I've removed the front door, inverted the window. I have some carbon fibre en route for the top of the front bezel to make it Lian Li style, and I'll be filing down the drive framing tomorrow to make it more defined and add more contrast (you'll see). So far here's what it looks like, very plain, but I haven't even scratched the surface yet
My plan is to cut out the front fan holes and add in a grille like found on the Coolermaster 201:
Unfortunately the problem is I can't find this type of small-hole mesh anywhere! All I can find is this:
http://www.mnpctech.com/
I also found this stuff which is very cool and can be painted any color, problem is that its also big-hole..
http://www.store.yahoo.com/tyfoonmotorsports/jdmalgrilmes1.html
Can anyone help me on my quest to find this type of mesh? Preferably in chrome...it doesnt have to be made for computers or cars, just any object (aside from buying a 201 case that is
) that I can slice up that uses this kind of mesh, I want it so bad!
