Cooler Recommendation
axistek
Hey Guys,
I just recently purchased an ASUS P8P67 WS Revolution, 2x 4GB Corsair Vengeance memory sticks, and a 2600K cpu to finally do an upgrade to my system. I know there are some spacing issues with Corsair Vengeance memory and that is why I need some recommendations. I want to be able to use all my memory slots in the future. By the way, the case I'm using is a Cooler Master CM830. Thanks for the help!
The best way to avoid clearance issues with RAM is to use either the H50 or similar, or go with a full blown watercooling setup.
the Zalman CNPS9900 and Max model are pretty slim tall HSFs. should clear with no issues.
This. Used H50's go for ~$45-$50 on forums. A Thermalright Archon should also fit with tall heatspreaders on the RAM, but I cannot guarantee this. There was a post in this thread where someone had an Archon on an ASUS P8P67 Deluxe P67 board and it looks like it just fit.
I was really considering the Thermalright Archon, but I am still worried if it will fit on my CM Stacker 830 case. If I go with one of the Corsair H series coolers, I would probably go for the H60. Has anybody already tried the H60 and can give me some feedback?
