Getting kind of miffed with this saga. After getting a cooler as part of a discounted combo, I find that I need additional bracketry for my 1366 socket. (I didn't check compatibility because why would you combo them if they weren't.) So I breakdown and order it.
I don't have that much free time to work on this build, so this weekend now that I have some time, I find the Backplate that came with the additional bracketry is not flat. 4 feet need to go on the bottom side of the board under each cooler mounting hole. But only 3 will touch. One foot will be lifted and have about ~3 mm gap.
Cooler
1366 bracketry
Now the additional hardware uses springloaded screws. So that can make up for a multitude of sins, but can it make this still work?
The problem is that this thing is almost 3 wks from purchase date and most of it is covered by a 30-day return policy and I haven't even posted it. I can't wait anymore for a replacement bracket.
Its either go with the bent bracket and this cooler or the stock cooler that came with the chip (i7 920)?
Cooler
1366 bracketry
