Cooler Master V6 GT: Thoughts?
I3eyond
Was looking at the 212 Plus, however I came across the V6 GT and from nothing but a looks perspective fell in love with it immediately; it would go great with my HAF922.
I don't overclock, however Friday I will be adding a second 660 Ti for SLI and figured it wouldn't be a bad idea to add an aftermarket cooler to keep things as cool as possible.
It will be for my LGA1156 i5-760.
Thoughts?
And, I guess most importantly....would it fit into a HAF922?? I see it's huge.. lol!
Love the V6 GT. The reviews on it say that the mounting system is a little bit loose, meaning you can wiggle the HS after you mount it which is not ideal. Also you need to use LP ram because it sits very low. Other than that I like the look myself and the fans have great airflow and it acheives nice temps. I don't know about the size in a HAF 922. I just got back a 0 of 233 hits on Newegg reviews when I enter HAF 922 in search. Not a good sign.
I have a HAF922 and a Coolermaster V6 GT.
Yes it looks great, also keeps my 4ghz Phenom II X4 cool.
Do you have a fan installed on the side panel? Wondering if it would interfere with the V6 GT....
I have no fan installed on the side panel, but after looking at it, looks like it might (barely) fit.
The side panel on my 922 has a bulged section, this itself adds a lot of clearance.
