Cooler Master Storm Enforcer
HardOCP News
[H] News
Overclockers Club posted a review of the Cooler Master Storm Enforcer mid-tower case today for those of you interested. The OCC crew gave the case high marks, here's a quote from the review:
The case itself is a small mid tower with a side panel window that takes up about half of the side panel itself. There are only two fans provided from the factory, and that is one 200mm front intake and one 120mm rear exhaust. There is room for two 120mm fans up top or a single 200mm up top.
Hmm, it still has a 270mm graphics card length, just like the Coolermaster Storm Scout that I have at home. I had to dremel part of the drive bay to fit an AMD 6950 in it this past weekend. It's a really great case, otherwise.
It has the 270mm length, but the upper HDD cage is removable so no problem fitting cards in there unless you're running more than 2 hard drives.
I need a new case for my SB stuff and this one is on my list, but I'm really holding out for Fractal Design's Arc Midi, I think.
Ahh, gotcha. The HDD bay in the Storm Scout is only removable if you drill out the rivets. :D
