COOLER MASTER Stacker 810 midtower?
Anyone out have this case? If so, could you tell me a bit about it? Having a hard time locating reviews on the mid-tower. Plenty for the full tower however.
eh?
the 810 is the same as the T01 but does away with the top psu mount in favor of a 2nd 120mm fan mount.
It does away with the cross flow fan as well. But really 80 mm fans needs to go and imagine what rad you can fit up there and at the bottom.
But otherwise it don´t feel like a severr upgrade. Priced the same really and I find it weird that they take away the crossflow fan. Also If I get the original stacker I can get 1300 W peak power with my two 510 PCP&C :D. I had planned to sell one but man would that look cool. Especially powering a mere air cooling system. Total Overkill :cool:
oqvist said:
But really 80 mm fans needs to go...
The 810 I recieve shortly will def get a couple mods. A 120 on the window and another up top sound good. So...
2 120mm Intake
2 120mm Exhaust
1 120mm MOBOflow on window
1 120mm Blowhole
