Cooler Master Sniper
Quality
IGNORE THIS QUESTION AND PLEASE HELP WITH MY SECOND QUESTION
I jsut wanted to know if any of you have this case and have modded it. I have one in the mail on its way, and I know I want to pain the inside of it black (which I have no idea how I'm going to do that yet), but I was just curious as to any other things I could do to it.
I was thinking of things like completely removing the mesh on the side of it and replaceing it with a window....things like that.
I think they case is great by itself stock.....but I have not been able to find any mods to it on the internet or sites like frozencpu.com.
THIS IS THE QUESTION I REALLY NEED HELP WITH!
one more question...i just went to my house for lunch and my case was there....I opened it out, and there is a peice of paper attached to the mobo tray, explaining where to put the mobo stand offs if you have micro or standerd ATX.
My question is 2 of the standoffs were already in place...the place they are to be used for both motherboard sizes, and are obviouly in place to show novice computer builders what the sheet and holes are used for.
..but my question is why are the two stand offs that are already in place for you, different than the other standoffs? Everyone knows what standerd standoffs look like, but these standoffs are narrower at the top then the rest of it...where all the other standoffs that come with the case are the same size the whole length, excpet obviously the part that screws into the mobo tray.
Anyone no why these two stand offs are different?
They are in slots B and E as seen in the 4th picture down from the front within this link (figures....they are not installed in this pic though:confused:)
Thanks,
~Quality
id say dont worry about it. if they are the same height as the others then just use them. if they arent or if you want them all to match then replace them. theres no reason for those to be different. if it really bugs you that much you can just call CM and ask try that yet?
No i haven't yet...like I said, I jsut ran home at lunch to check it out and noticed it...i'm at work right now, so I figured I'd ask here to see if anyone has this case and had an explanation for those standoffs and there purpose....
