Cooler Master Silencio 550 side panel mod: Wanted
Hi I bought a silencio 550, and am going to get liquid cooling, If there is someone who makes cases and sell them online that would be great, even if one time only, I would want this side panel to have a quality clear, or acrylic black (see through) with nice design (eg.
) and two 120mm grills connected to each other, for radiator cooling along with the sound proof foam, like the original, surrounding the window and grill, The grill would also have to have a dust proof mesh, like over the other grills, to stop income of dust. This radiator will pull air from outside into the case, through both fans, except the radiator will only have a pull configuration, due to width limitations. I will have a secondary 1x120mm radiator to help cooling and in a push/pull configuration, to pull the air out of the case.
scaled.php
The color would have to be the same as the case itself.
The sound foam (stock) looks like this, I am not sure where you would find this. The side panel uses, a hooking type of system to stay on the chasis.
scaled.php
Using this reference of what I want
Second style Idea
It would be quite expensive to commission someone to do this, why not make one yourself in the spirit of being [H]ard!
