I used the Fusion paint. I tested out a piece before actually spraying the case and it was adhering pretty well. After a week it wasn't as easy to scratch.
How did you mount the bottom front intake fan? It looks a lot better than the stock bracketHere's another update shot. Just letting it cure for 24hrs until I start putting everything back in.
And I stole it from youYou can't reach it from behind? I have the same psu and my power connector is in the same spot pretty much and have way more then enough length to reach it (see pics.) Don't know about the fans but I'd probably get at least a couple extra case fans along with the gpu cooler.
Also, heres a pretty sweet easy as hell mod that I stole from somebody
And I stole it from youWorks great.
^^Nice wiring! Man do I wish more MB manufacturers would put SATA ports horizontally mounted on the edge of the board like that!
Whats the biggest PSU that will fit without having to remove the bottom fan mount/screws?
I'm mostly looking at 800w+ PSUs.
This case is to small for future cards right? It can barely fit a 8800 GTX.
There's plenty of room for 2 8800ultras in this case. Future generations should not be a problem at all.
Aside from the CM fans that come with this case, what other fans are you guys using? I'm looking for quiet fans to use inside the case. I'm also debating whether or not I should get a fan controller for the fans I plan to buy in the near future.
My 8-pin cable wasn't long enough to run through the hole in the top of the case, so I cut part of the fan grill behind the processor off and ran the cable through there since I wasn't using a 80x15mm fan. That gave me enough room to hook up the 8-pin cable before I screwed in the motherboard.Thanks for the link I will order it monday. After I posted I looked back through the thread and I was wondering how you guys got it to reach, and I thought it was somethin that came with your power supplies.
Updated pics of wire management. Made the hole in the mobo tray bigger since about half of it was covered by my psu. Need extensions for the P4 and 24 pin so I can get them out of the way.
That's what I did, and it works fine.Why don't you turn your PSU upside down so that the wires are closer to the hole? That will give you some more cable length.Your PSU doesn't have a fan on the top so it won't make a difference!
