Why do you hate your 680i stain.? I have the same board(the SE version) and it runs great and i am glad to see someone running a Quad on it.
it's fried several sticks of memory, umm.. 2 dead fan ports, umm.. vdroop is pretty unsubstantial. There are more reasons why. oh, it will not post with all 4 dimms filled with RAM. It overclocks alright, but heat was a factor when I started pushing 3.6ghz on my e6600. I've gone thru 3 or 4 680i mobo's and about 6 kits of ram. As soon as I get a laptop, I'm going to break down and get an asus p35 board.
Thank you, I knew it would, after seeing a number of peoples cases w/ the inside black I felt compelled to get mine from grey to black. Quote from a batman movie: "Does it come in black"Nice, the black interior really makes a difference.
Yep, I believe I used flat black(I was only gonna use FLAT or MATTE). You can all notice how my side panels appear to have a bit of a wavyness to them, I suppose that would be the (black) primer I sprayed on them before painting them, so I decided not to use any primer on the rest of the caseI like how you did yours , is it a flat black? I did mine with the whole black UV Package.
ahhh the flash!
thanks just got my watercooling up and running had to cut top of case to mount rad
Nice rig mate. Just wondering if you've had any troubles with that PSU and those 8800GT's. I'm thinking of getting a second 8800GT and I have the same PSU. Cheers.
Has anyone checked out the new nVidia version?
Where are you buying them?i have no problem with the psu and the 2 8800gt They just excellent at playing games.
Planning to change all the fans to the new coolermaster Long Life LED Fan 120mm (R4-L2R-20AC-GP)
Will post new pics once i get them
i have the same case...can anyone please tell me which will be the best possible place to place the UV rod? i have few lying around but i don't know where to fit in the case![]()
UV rod, as in like a cathode?
I just finished getting mine ready for my mobo and vid card that come this Wednesday. I have two fans in the top and I bought two 4" cathodes, put both of them right in front of the fans between the fan and the side panel. I think it will look the best there. I will post pics when it is finished![]()
