Cooler Master Quickfire TK Mechanical Cherry Blue Backlit $60 AR
Bought one of these when they were $65 last week. Great deal on a fully backlit mechanical keyboard.
The backlighting suffers from PWM flicker. Particularly noticeable because it's a keyboard so it sits in my peripheral vision most of the time. More noticeable as the brightness goes down.
Construction quality isn't up to par with the Quickfire Rapid it's competing for space on my desk with. Cheaper feeling plastic housing and key caps, kind of wonky stabilizers on shift/enter/backspace.
Backplate has some flex (not bad, but it's there) compared to the rock solid Rapid.
Highly recommend the Rapid over the TK unless you really need a backlit keyboard, the Rapid offers a superior typing experience.
How's the quality on these CM keyboards in general?
I mean if I'm spending like $80-90, I might as well not give a fuck about $30 more or something and get something nicer yet. I've had the same keyboard for over a decade, and although it's seemingly constructed from some supernatural and subsequently unbreakable material which lies beyond current scientific understanding, I think it's getting near time for retirement.
I'd imagine it'll be a solid investment...
The "in general" part is a problem, since Cooler Master seems to use at least 3 different OEM manufacturers for their keyboards.
Rapid (including Stealth) and XT are made by Costar, the rest aren't made by Costar.
Rapid/XT > Trigger > TK/Ultimate? > Pro > Quality Scissor switch >>>> Rubber Dome
Jeez, I didn't even know they had the Ultimate until I started looking around. Anyways, try an Ultimate yourself, I'm just putting it by the TK because they look very similar build-wise and might be from the same OEM.
Get a Rapid or XT, they're magnificent.
I bought the red switch/backlit version for $75 a few months ago. I use it strictly for gaming and am very pleased with its performance. For only $60, I'd buy this blue one in a heartbeat if I didn't have the red one.
