Cooler Master question
HAF72
1337 :)
Hey guys, I have a cooler master HUC-E8U1wc system. Anyways I was wondering what was the width of the tubing for it since I am going to buy tygon tubings for it. Is it 3/8? 1/2? Also another question, it dosent matter which slot I connect the tubings to the wc system right?
I belive the tubing is 1/4 ID, but I'm not sure of the outer diameter. Can you measure it?
:confused: :confused: What?
Yep. Measure the entire outside diamter of the tube with a ruler... report it in mm and convert it to inches.
