FreshPrinceOfBellAir
- Jul 7, 2005
I'm trying to build a reasonably quiet PC to place on the desk near the monitor. How's this unit? I know a lot depends on what is going inside the case, but with 4 fans I'm thinking this will need a fan controller to help keep things under control. If it's "too loud" would Dynamat help? (I heard this will raise the temps and dosen't help that much
) Should I try some of those silicone fan isolaters? I know all this stuff helps, but is it necessary to keep this case queit. I wont be OCing. Thanks
case
[URL=http://www.newegg.com/Product/Product.asp?Item=N82E16813999504]Controller[/URL]
silencer
edit: I'm a retard
case
silencer
edit: I'm a retard
