Cooler Master Hyper 212+ & Thermalright TY-140
radeon962
Just curious if anyone has tried fitting a 140mm Thermalright TY-140 on the Hyper 212+? The TY-140 is a 140mm fan but is made for a 120mm mount. Seems like the dimensions on the Hyper 212+ would allow it.
I want to split the pwm CPU header on my GA-P55M-UD2 for a TY-140 on the CPU and then a TY-140 for the rear exhaust.
Might just go Scythe PWM, but the idea of a 140mm fan pushing more air at lower speeds sounds good.
Thanks, Bill
The brackets for mounting the fan to the Hyper 212+ hold the fans by it's flat sides. There are no screws used. I think you're going to have a hard time making that work.
That's what I am gathering. Looks like I'll just get Scythe Mugen-2 Rev. B.
Looks like the best of both worlds and about the same price if I were to get the Hyper 212+ and a TY-140.
Thanks, Bill
