Cooler Master Hyper 212 Question
fightingfi
has anyone purchased this item and had it fit inside a Antec 900 case "with" the side fan also? Is it best to get another fan for it and what fan should i use\get since it came with one fan and how would you plug it into your motherboard with most boards only having 1 4 pin onboard connector
I can tell you that it fits in my Antec 300, with two fans on it and both the rear and top case exhaust. I bought an identical cooler master fan to go with it. You can buy a PWM Y-cable to hook both up to the motherboard connector, or you can do some soldering of the wires yourself.
