Cooler Master H500M White Edition!
Chase0023
Well I haven't built a computer in ages.
Looking at past few years, I gotten to like the Cooler Master 500 series.. especially the H500P mesh white.
I wanted to do a RGB computer like some of the trend I've seen, so Unicorn puke it is...the white would help it stand out like a lot of the builds I see on youtube.
I bought one after I stalked it when it went on sale.
The case sat for awhile, as I was collecting parts and etc.
I bought a NZXT AIO and was and was thinking I could put it on top and do a push pull so you could see the RGB fans from the top as well. I was set on this then disappointment arrived when I took the case out finally to measure and see and behold, can't fit a radiator and a fan on top and bottom. It was not enough space..
It's not a big deal but then u like what you like and don't like.
Also noticed that the front 200mm fans would not be great in syncing with the rest of the ARGB fans.
Damn it, why can't anything go the way I want.. LOL
So I decided to look and behold, I find the H500M on some Youtube videos and find it has the features I want with the front large ARGB fans and be able to mount push pull config with a radiator on top.
But alas, this damn case only comes in black.. why why.. always never what I want.. Always in pieces here and there.. Sigh..
So I decided to paint and powder coat my H500M white to be a little different from most with a H500M.
At least this time I don't need to cut holes and grommet them, when it wasn't really a trend back then when the cases hardly had any routing holes with rubber cover and etc.
All the metal pieces were powder coated matte white and the plastic pieces I decided to paint those myself in matte white.
I hope to build a cool looking all white build but there so many out there we will see..
After a week or so.. got the parts back.
I was thinking about taking apart the fans and just coloring the frame all white but then too much hassle so I decided to keep t he contrast with the rest of the case.. I think it looks cool..
Still not done yet.. Gotta touch up some of the pieces.... To be Continued!!
My NZXT Kraken Z73 white edition... I didn't want to paint the radiator all white due to heat issues so I only painted the outer edge. Fins are not painted but I am sure you won't be seeing it when fans are on top of it..
Finally I am done with the Cooler Master H500M "White Edition"
I really like how it came out.. Look really clean and with the black accents looks really good..
Looks even better than the Cooler Master H500P Mesh White...
That white plastic piece that covers behind the mobo, I forgot to put it on but no matter.. LOL
So empty and free.. before the assembly began..
Solid Red Oak Box I made to house an internal Blu-Ray Drive and USB 3.0 hub on the side..
Some of the contents I need to fit...
Corsair RGB module x 2
Corsair Commander Pro x 2
Lian Li Streamer box x 1
NZXT USB hub x 1
and so much wire... it wouldn't all fit... I had to do lots of wire management in the back just to fit the wires.. It was a pain...
The front is so much less clutter than the back...LOL
Still missing that GPU... I need an ASUS Strix 3080 in White.. damn it.. LOL
The Unicorn Puke begins.. LOL... I think I need more.. hahahaha
I still haven't ripped off the film off the windows... It won't be until I install a damn GPU!!!
I think the lighting on your parallel wires being out of sync bothers me more than the frag harder disco lights themselves.
I basically just plugged it in and turned it on.. No adjustments whatsoever..
No GPU so I am just waiting to set everything up and align and time all the lights later..
I was just anxious to post a pic.. LOL
Just out of curiosity what do you mean by my parallel wires? the Lian Li Streamer cables for the 24pin and the gpu 8 pin x3 cables?
Both. Primarily different wire groups within each because unless the GPU and mobo cables are the same length it'd be impossible to have them synced in both speed and duration.
