Cooler Master H500
Can you post a pic of the trouble?
A 200mm should fit fine like this:
Ok so where you have typed the *200* mark on the INSIDE of the case is a groove that DOESNT allow the fan to be pushed in to line up with the holes its a small gap that wont allow it to fit in .
ok, this ISNT my Pic but here is what happened and is going on, the noctua wont fit into this groove
Pic again used for reference is this a stock case fan used in the top for this case. ( It seems my old name has been unblocked so its me posting)
