Cooler Master Elite 341
zchen
Looks like Cooler Master has came out with a replacement for the 340, the 341; the 340 is no longer listed on the cooler master's usa site when I checked.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119193
I like the all black look compared to the 340's black with silver trim.
Hopefully my local fry's will be replacing their 340s with the 341 so I can go pick one up.
Interesting.. I can't tell which I like better.. both have their positives.
All I can say for sure is holy 120mm fans galore.
I was thinking 240mm rad in the front, and an additional 120 on the rear- all internal. :D
I have one of these. The front is fairly solid outside of the air filter for the 120mm fan, so using two upfront would require a bit of modding. There is a 3.5 hard drive bracket on the floor behind the 120, but it's too close to leave in place if you're going to put a radiator there.
About to pull the trigger on this case. I have the Centurion 541 put I can use the extra 1" and change on depth, plus the four 120mm fans seems like a good deal to me. Can't be worse than the 541, that thing feels like it's made out of Pringles cans.
I just sold my Elite 340 and all in all it's a good case for the money. My only issue really was that if you have a noisy HD, that frame will amplify vibrations a great deal. The seeks were really noisy with my Samsung 500Gb (now known as SPinpoint F1 I believe). Sure it's no Antec case but then again it's really cheap.
Get some silicone mounts for the HDDs maybe?
If they had bottom mount the power supply and add a 120mm at the top... This would a be the perfect mATX case.
