Cooler Master Cosmos 1000 w/OEM Window- Vertical GPU Mod
Discussion in 'Cases & Case Modding' started by MATRIXSHARK, Oct 13, 2018.
  1. MATRIXSHARK
    MATRIXSHARK Gawd
    815
    Nov 2, 2007
    The purpose of this Mod is to showcase the GPU
    This styling and build quality of this classic 2007 case still holds up suprisingly well:
    (stock photo)
    First Mod was to source and purchase the OEM side window. Being out of production for about a decade made this INCREDIBLY difficult.... At this point, it's probably easier to modify the original side panel and add a window yourself. But, I ended up getting very lucky in finding one.
    (stock photo)
    Now for the location of the Vertical GPU mod:
    That dust filter's spot will do nicely. It will allow plenty of room without interfering with the standard expansion slots.
    But before I hack into it, I'll need a donor case to source a bracket from:
    You can see my pencil lines sketching out where the cut will go.
    Here it is liberated from it's donor:
    I'll clean up the edges a bit etc.
    Test Fitting it into place with and without a GPU to get an idea of fit:
    and
    That mesh on the case get's dremeled out of course. Then the bracket can be drilled and riveted into place:
    Almost done!! But, I'll need a PCIe riser cable. I got this one off of Amazon for about $26:
    GPU goes in:
    And Lastly, the case cover is put back on:
    (ROG STRIX Pictured here)
    Overall, it was a fairly straightforward mod, But one that was both in-expensive and worthwhile.
    Comment below!!
    Gavv and Engr62 like this.
  2. M76
    M76 [H]ardForum Junkie
    8,328
    Jun 12, 2012
    Without vents in the side panel I doubt this helps with cooling. Did you check temps before and after?
  3. MATRIXSHARK
    MATRIXSHARK Gawd
    815
    Nov 2, 2007
    Oh, I agree. This is ABSOLUTELY a cosmetic mod. Purely for looks here... But I will say that temps are fine.
    Being 11 years old, the Cosmos 1000 chassis itself is moderate for airflow.
    While I didn't do actual measurements, Temps after the mod are perfectly fine. GPU is 60c (plus or minus a degree or two) at load.
