Cooler Master Centurion - weak fans?
rx jr.
I purchased a Cooler Master Centurion case about a month ago, and i'm really disappointed with the fans.... I put my hands right on the fans, and I barely feel the fans blowing air. anyone else with the case have this problem?
or am I just screwing things up again!?
thanks
Never had problems with mine. Sure you have it plugged into the correct molex?
rear case fan goes into case fan 1 on mobo
front case fan goes into case fan 2 on mobo
can't get more straightforward than that, right? ? ? ?
:confused::confused::confused:
If they're the 0.06A fans, then they're low-RPM. The front case fan is 80mm, so it won't move much air anyway. Replace them with the medium-speed Yate Loons and be happy, that's what I did. Or better yet, move to an all-120mm case like the 690 and stick 6 fans in it if you want tons of air moving.
i just checked and it's 0.16A. horrible! it moves less than 11CFM, and I know this because it moves less air than my other Cooler Master fan!!
:mad:
same problem with the 80mm in the front... no difference in speed when I plug it into a 4-pin. disappointed.
what is this medium speed yate loon you speak of?
