Cooler Master Centurion 532
grumnpy49x
I just replaced my old case with the above Cooler Master and now I am having problems with the computer starting. Before I can start I have to turn the power off then back on and it will start other wise it won't. I the computer is turned off either through windows or by the power switch, when I go to turn it back on I get a brief surge that starts all of the fans then immediately powers off and the power led stays on. If i reset the computer either through windwos or the reset switch I have no problems. At first I thought it was my power supply because after installing it in the new case the first time I turned it on I saw a spark. Since then I have replaced the power supply and the problem is still there. Could it be the power switch or could it be the mother board itself? Thanks in advance, Doug
make sure that the motherboard is not grounding out on the case in any places and that all of the stand offs are properly aligned and secured.
