Cooler Master Blue flame MbK
kier
Sponsored by:
Thanks to : Marco, Ruud and Maikel.
And thanks to: Niko
Hardware:
- CASE: Cooler Master CSX Blue Flame
- PROCESSOR: Intel® Core i7-2600K
- MOBO: Gigabyte GA-Z6X-UD4-B3
- GRAFISCHE KAART: GTX680
- GEHEUGEN: Corsair Domnator 8GB (4 x 2 GB) 2000 MHz Quad Channel DDR3
- HARDE SCHIJF: 256 GB SSD
- OPTISCHE STATIONS: Sony optiarc AD-7670S
Who doesn't know them, the Cooler Master CSX series. The beautiful paintbrushed Coolermaster Stackers 830
I've always wanted to mod this case. Luckily I've made a great deal to with Cooler Master
The only condition was that I wouldn't do anything to the outside. Hmmm ok ;)
So a build entirely focused on the inside.
The Cooler Master Stacker 830 CSX Blue Flame:
Sorry but need to strip it ;)
For the outside I may not use my dremel ... but inside oww yes here we go :)
Marked some lines for a 360 radiator.
On top of the fans there will be a piece of bended mesh.
For the front I've made ​​a cover for a 240 radiator.
I've also made a slot ​​for the Sony slimline drive.
And pasted some nice black glossy vinyl over it.
More soon!!!
Another update!!!... have some finished already ;)
First my thanks goes to EKWB which still believes in my builds ... Niko Thanks for this
What I am going to use from EKWB in this build:
A beautiful old school EK-Supreme HF
A EK-CoolStream RAD XT (360)
And a
EK-CoolStream RAD XT (240)
Also an EK-DDC Dual Top (V.2)
Some accessories
Not to forget the beautiful EK-FC680 GTX Acetal/ Nickel
With a EK-FC680 Backplate
Also some Fittings and adapters
Placed the GPU block on the GTX 680
After some brainstorming and trying, I've cut and bend some aluminum strips and cut an old 150mm reservoir (round 60mm) into 3 equal pieces. It was very old and had some cracks so no problem ;)
Placed reservoir holders on the aluminum strips and slide 3 older versions 150mm (round 50mm) reservoirs in it.
Connected them using EK adapters + C47 multi links and crystal links
Placed the GPU and CPU block also connected them with EK adapters and Multi Links
Installed the EKWB top on the pumps and put it under the last res
And last, I have adjusted an existing sleeved PSU with the beautiful MDPC colors Black and B-Magic
That's it folks ;)
Awesome bro. I was just looking at my CSX Hellraiser and thinking of putting it to good use. :)
You've got the red skull hellraiser? love that one too
think it will look great with ROG theme inside
update!!!
Did some fun stuff with aluminum in this update. Cover for the sidetop
And the side cover
The whole picture
Made it black
Did the mobo tray also
And some pics by daylight
Also placed the airbrushed covers back
Thought of nice touch for the 3 tanks, for this I used a nice piece of blue glow acrylic.
Measuring and marked
Drilled holes
And some sawning
Cut it in half
Placed it
Pulled the plastic off
Cut out 3 circles to the size of the res tops
And placed them on the top of the caps
Connected all of the Acrylic tubes
Need a controller :)
For this I have used an old Aquaero. This time the blue version
In the top cover ivé cut an opening ​​for the display
The controller itself I'm placing somewhere else using a custom flat cable.
On top!
Made somekind of bracket and blackened it. Also placed 2 poweramps for dual pump control
Standard Channels Aquaero dont like 2 pumps ;)
Minor change of plans .... I usually do everything with acrylic tube 12OD / 8ID but thanks too Nate I can use 12/10 this time.
Thanks Nate!!! More beautiful products in the E22 shop
Placed all sleeved cables.
And added some blue details.
CPU cover
Fan cover
And a nice total shot for last :thumb:
More to come!!!
Another update!!!
Pictures from a filled stacker
Sit back and relax.
And after a night running the pumps, everything is fortunately dry;)
Done some last jobs before the power goes on.
Controller connected with sleeved cables
Some more glossy black
And the pictures with the caps back on.
Power on!!!
Hey Richard I may have to borrow your rad in the floor idea. I was gonna double stack two rads in the 5.25 bay area but since EK never responded to me I'm gonna use my Black Ice 480 in the floor. Hope u don't mind!! :)
I like everything about it. I've never seen a build like this. That blue flame looks like it is floating. Congrats.
