Cooler Master ATCS 840 - 56k Beware
soulesschild
Edit: Here they are!
http://flickr.com/photos/soulesschild/sets/72157610185530325/
So I just bought a Cooler Master ATCS 840 Silver (I wanted black but decided after I saw a model in store, the reason behind this is that the model in store showed that the black aluminum showed scratches REALLY REALLY easily). Note that I don't have my system hardware inside it yet as I'm writing this review at my parents house for Thanksgiving break. Once I get back home I'll post some pics with my stuff installed inside.
Unpacking:
I bought this retail for 255+tax = 277. It came in a box with the usual styrofoam case holders + a plastic bag around it. Nothing fancy, nothing too special. Initial examination showed no scratches or otherwise obvious damage to the case due to shipping or packaging. The cardboard is very thick and should hold well if you were to order this online.
The box of stuff (GPU fan thingy, screws, etc were packed inside the case nicely and showed no signs of moving around. They actually have like garbarge bag ties holding it in place agaisnt the mobo tray, so no worries of it flying around during shipping and damaging the fans or anything.
It's fairly light, site says 30 lbs, but felt INFINTELY lighter compared to when I bought my P182.
Exterior:
The outside of the case is extremely nice, has the rough feel of aluminum. The only thing I don't like is the fan grill for the top fans are black, but I guess it contrasts fairly well. I can't imagine what a silver mesh would look like, but just for like, overall look...uniform look, it looks a bit off. The pop-up front IO pops up nicely and smoothly. Though I have no idea that if it somehow breaks, you can fix it or not. =/
A bit annoying is that the side panels make a slight noise (I can't really describe it but it's a noise you don't want to hear) when you put a bit of pressure on them when you have them off the case. I don't know if that's just the aluminum building construction, or a defect. Not sure if we have a CM rep here to answer these questions =/. Another thing that's irritating is that the feet feel like cheap plastic. I mean come on CM, least you coulda done is use some better material then cheap plastic??!?! :confused:
Interior:
Interior is beautiful, very nicely done on Cooler Master's part IMO. The mobo tray is very nice and the handle on the mobo tray has a very...solid feel to it. It's hard to describe but when you pull on it, it just feels firm and sturdy. The actual mobo tray is very nicely laid out. It's got a piece of paper on it that's labeled which holes to put in for the different ETX formats, m-ATX, ATX, and E-ATX. The ball bearings in the mobo tray make taking out the mobo feel smooth and silky. No metal grinding on metal. The fan filters are very nicely done, shouldn't have a dust problem in this case! You have the huge fans on top of the case, 2x230x30mm which can be removed if you plan on installing a rad, though I'm not sure if you can have both at the same time...might be counter productive but who knows?! :). A fan on the mobo tray, standard 120mm, and another 230mm intake fan in front, which you can't replace with anything I believe. Though if it breaks, CM should sell replacements. It's also got a ginormous fan filter as well :)
Though, what I think is a design oversight or error is that the PSU intake filter, if you have something installed like a fan or something on the bottom middle intake/exhaust, you have to remove it to remove the PSU fan filter. Also, some people might not be a fan of the way the HDD mounting racks are. Feels a bit...cheap. But should get the job done.
Extras:
So some extras! As you can see from the picture, CM has a load of stuff lol. Fan mounts for mounting rads or HDD fans (though I feel like they shoulda included more, what if you want to mount HDD fans AND a rad? You'll probably have to cough up some extra money for those parts) A REALLY nice thing that CM has done is include an 8 pin PSU extender cable! That's something I think is pretty genius and thoughtful of CM. I know my HX620 has issues something reaching the connector in my P182, even more so now probably on a full tower. The GPU/PCI-E exhaust housing is still somewhat of a mystery to me but it mounts fine and looks fine. Other then what you normally expect, cable management ties, screws, it's pretty standard stuff. The manual is a bit sparse in terms of wording, just mostly pictures, so this might hurt some noobies try to install stuff, but generally pretty clear.
Overall:
I plan to WC this, probably going to put a triple rad on top, and a 240 rad on the HDD rack if it doesn't adversely affect my HDD temps (any WC nut want to supply some input?) But overall, I'd recommend this case to anyone who's looking for a full tower aluminum chassis and doesn't want to pay for a hugely overpriced IMO Lian-Li. It's beautiful, it's big, and it kicks some serious ass in looks and functions offered!
u lucky bastard :D how much and where did u get it from?
Also a lian li pc a70 is cheaper then this and has a similar interior
nice case and good writeup....I ordered one from Amazon $262 shipped, won't arrive till after Christmas though....good thing I'm in no rush :)
I got it from Central Computers for 277 after tax. The original price was something like 255?
While it looks like it would be nice to work with... I've got to say I think it's fugly.
...and I mean that in the best possible way.:)
I can see how some people won't like the design. It's defintely not as nice looking as my P182, but hey, I'm gonna WC this beast, maybe cut a side window ;)
Could you tell if it scratched easily as well? I don't mind if it scratches show easily, as long as it's the paint is somewhat durable :D
That I did not try :D
Haha, didn't know if people would appreciate like 50 hi-res pictures loading on forums :p
I thought the same thing. I have an old ATCS case 200 something model, the one with the thick brushed aluminum front (that is real solid aluminum held on with screws). I LOVE that case it is rock solid.
I hope they bring the quality level of those cases back. They were truly beautiful cases and CoolerMaster made ultra high quality cases at that (until their design staff left/was fired (don't know which) to form SilverStone.
Glad to see some buzz about this case. Think I'm picking one up around February and getting rid of this LL. I haven't been too happy with.
Gotta disagree on the choice of case colors, though. Maybe it's just the photos, but silver looks boring as all hell. I'm going to have to go black.
And yeah, I was kind of surprised at their choice for the HD cages. I know they saved some cash using the same cheapo stuff they use on everything else, and it's a minor niggle, but I was hoping for better from them. Still, as long as the damned things are quiet, I don't really care that much. I guess it's as good a place as any to save a few pennies.
How quiet is the thing?
-S
