Cooler Master 690
auceny
Can anyone tell me if the CM 690 has enough room to fit a MCR220 with fans on the inside top where the factory fan mounts are. I'm wondering if the fans/radiator would interfere with the motherboard and components. I'm trying to find a case around $100 that could fit at least one MCR220 internally, side panel, and bottom mounted psu. I've been checkin ebay for used lian li's as well since I don't want to afford a new one.
I think the 690 is close to the same as my 590. If your MoBo has things mounted fairly low, you can squeeze the loop in there, but it will be tight. The way I plan to do mine is mount the rad on the outside, with the fans remaining inside. As it stands, I think your way would fit, but you would definitely have to use 25mm fans, and connecting hoses would be tough.
thanks for the response. i have no idea what i actually want. i started looking at the CM Cosmos 1100 too now. too many options out there!
