Just checking. I'm looking into buying / replacing fans that came with it. So far, it comes with a 120mm for the front (LED) and the back (regular). I was going to replace the back 120mm with an LED, place 2x 140mm LED fans for the top 2 vents, and then was thinking about anything else.
I'm really aiming for quiet here, so I'm going for the Yate Loon low speed fans. Should I put 1 fan on the side panel of the case, or not worry about it?
