Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
It says it has mounting holes for 1151, so at the very least, it will mount on the motherboard.
Not sure how well it will do, though, and can't tell either if you'll have RAM clearance issues, PCIE clearance issues, and case clearance issues. The latter three will depend on your specific motherboard and case.
