Cooler for i7 930
grhgorop
Hello, for my new build, i am buying an i7 930. Do you think i would be ok with the Prolimatech Megahalems Rev.2 CPU Cooler? Should i also buy an extra fan, or i would be fine with the one in the box of the 930? I am kinda noob :eek:
Thanx!
The Megahalems is one of the best heatsinks available. It would do a great job of cooling your CPU. And yes, you will need another fan. The one that comes with the CPU is not meant to be removed from the heatsink and is also not the proper type of fan for mounting to a heatsink like the Megahalems.
Thanx!
i have an i7 920 O/Ced to 4 ghz with a cooler master V8 and it runs at 40 C, maybe 55 C at full load
If you don't intend to overclock past about 3.6Ghz, then stock cooling (and close to stock volts) may be fine provided adequate case ventilation.
If you intend to overclock, then:
"Normal" performance heatsinks: Cogage True Spirit ($35-$38), Thermolab Baram ($33-$38)... I've also seen the Scythe Ninja 2 rev. B for about the same price (under $35).
BIG Higher-performance heatsinks: Thermalright venomous-X ($55-$65), Prolimatech Megahalems B.
Top Tier Dual-Tower enthusiast heatsinks: Cogage Arrow ($58-$60), Noctua NH-D14 ($70-$75, but comes with 2 Noctua fans - however those fans are outperformed (even with respect to noise) by cheap yate loon fans)
My favorite fan choices for heatsinks based on performance/noise:
Cheap: Yate Loon D12SL-12 from Petra's Tech Shop (They have real Yates)
Expensive: Scythe Gentle Typhoon AP-15 1850rpm (koolertek had some deals recently)
Obviously the Yates are the better deal, but the Scythe GT's do perform slightly better. I'd put all of my fans on a voltage-regulating, non-PWM fan controller - I keep my Scythe GT's at 9-10v, which seems to be the sweetspot.
Honorable mention: Zalman ZM-F3 ($5-$8)
Places to buy (and check prices): [I've had positive experiences with all of these places, however I know some people don't like performance-pcs].
Sidewinder Computers (owns Petra's Tech Shop now)
Jab-Tech
FrozenCPU
SVC compucycle
Koolertek
Heatsinkfactory
Performance-pcs
I may be missing some other stores...
And other people have different fan recommendations - may as well get more opinions, but this type of information has been posted numerous times, so a search may prove useful.
I'm sorry that I cannot give you a definite ranking order for the heatsinks.
I'm going to be using the Corsair H50 on my i7 930. You can pick them up pretty cheap from Tiger Direct. :cool:
If you wanted the Zalman ZM-F3: http://www.ewiz.com/detail.php?p=CA...4f970d035d1164f24c86b4c73efc9461ac28b70afe368 - ewiz has it for $5.08. Some tests show it outperforming the Yates through a radiator.
Note that the ZM-F3 and Yates will suffer reduced life when positioned horizontally due to the sleeve bearing.
Corsair H50 will work fine. It's compact, and performance is probably about as good as that of the "normal" performance heatsinks (but definitely a notch below the Ven-X and Mega).
Here are some more easily digested fan tests:
http://www.overclockers.com/65-fans-tested-megahalems/ (This guy tests some high-end fans, so they steal the show... but the Yates are doing well. The D12SL-12 LED is somehow outperforming the slightly higher RPM non-LED version, so perhaps the measurements aren't fully accurate, but they confirm a trend). - he also seems to like the Coolermaster Blademaster and R4 fans.
http://www.xtremesystems.org/forums/showthread.php?t=170224 - ZM-F3 and Yate Loons are doing well (note, Nexus D12SL = lower RPM straight-blade Yate)
