Cooler for eVGA 680i
ascarytiger
I'm getting ready to purchase the eVGA 680i (A1) motherboard that will be paired with an overclocked C2D 6300. What would you guys recomend for a heatsink? I don't really want the Tuniq because of its size. I was thinking maybe the Zalman 9500 or 9700. Any thoughts?
I'm using a 9700 and it is working great, Q6600 @ 3.2 58C with prime 95 heating all four cores to the max. It hangs over the side of the motherboard a little bit so make sure you have enough room though.
I'm loving my 9500! e6600 @ 2.93, Load less than 48C... A lot easier to install than the stock fan, quiet, looks awesome too!
No i haven't looked into the ultra 120, although I have heard of it. I'll look into it, but the 9500 is looking promising.
Well Im pretty sure the Ultra-120 is regarded as the ferrari of all heatsinks
The 9500 really isn't that good compared with some of the other coolers like the Scythe Infinity, Thermalright Ultra 120 and Tuniq Tower.
I have the ultra 120, it hits the hs on the northbridge chipset, that is if you want it facing back so the fan can blow out the rear. Sideways it's ok, but then it blows towards the PSU.
I'm gonna go back to the 9500
the stock fan is back on for now
