Cooler CPU from OC
Postal Dude
I jus upped my winnie voltage to 5% over volt. And pushed it from 2Ghz to 2.5.
When it was at 2.3 and 2.4 temps while running P95 were in the region of 48/49. At 2.5 it seems to have settled at 44. Anyone else confused?
hmmm you could be right. It is quite a chilli day. still tho. not a bad result. Shame about my pooey memory makin me run a lower divider. CPU brute speed is faster but with less memory bandwidth. Will probly have to get it upto about 2.7 before im back at 200Mhz memory clock
Edit: Done the math. With the 133 (3:2) Divider. I would have to take my poor lil winnie upto 3Ghz to reach 200Mhz at the memory. So its back to 2.4 at 200Mhz memory. think i will get better performance from that
u could lower your multi and up the fsb that way your mem will be running at higher speeds while your cpu's clocked higher as well. either way having ur ram run with a divider doesn't hurt your performance that much.
