Cooler choice
Anagog
Im considering the NH-C14 but the BeQuiet Dark Rock Top Flow that is due out soonish also looks tempting. I'm currently using a H100 with NF-F12's and the pump is the loudest thing in the system which is why I want to change it out for an air cooler.
I assume you have limited CPU clearance as down-flow coolers usually make case run significantly warmer than tower coolers.
