Coolbits?
Does Coolbits still work? Now with the nvidia control panel you can change the clock speeds, but they revert back after restart. Is it possible to prevent this within the nvidia control panel, or do I have to use Riva Tuner?
Thanks
Coolbits works for me... though I can't stand the the new control panel, if thats what you're reffering to. If you have an 8 series card, you can still do coolbits 3.
If you want the Classic CP, there is also a method that you can use to get that back.
I don't remember the exact process/am too lazy to look it up.
Google "SedonaDisable" and something should pop up.
I installed it but I didn't notice any difference, the clock speeds are already unlocked, unless I did that. The prob is that they don't stay that way, after reboot they revert to default.
