Capfarland
- Oct 18, 2006
Does anyone know why this might happen? I use rivatuner, not sure if that has anything to do with it.
NvCplDaemon - Relates to the Nvidia System Tray icon and related functionality. If you don't use the System Tray icon to access the Forceware Control Panel settings - and it's certainly not necessary - then you can remove this item. Note however that if you're overclocking your graphics card using the Forceware Control Panel (See the Overclocking section) then you need to keep this item in your startup.
