cool running video card for Shuttle XPC
joormotha
Started up playing World of Warcraft and it's been taking a toll on my Geforce 4ti 4200 . I have an aftermarket heaskink/fan, but it isn't cutting it. I have to pull the case cover off and let my desk fan blow on it. So I'm looking to upgrade, but don't want to break the bank. Since I'll be building a new PC or buying a laptop next year, no point in getting the latest.
Seems that the Radeo 9600 pro is my best bet, but I'm more of a Nvidia fan due to driver stability/quality. I was thinking of going the Geforce 660 GT route, but am worried about power usage and board size. I don't plan on moving to other games, so I just want to get the most I can out of WoW without the system overheating on me. It would be nice if the fan ran quiet as well.
Other components:
v1 SN85G4
Athlon 64 3000
1 GB ram
250 GB Seagate SATA
Well, I'm running an Athlon64 FX-60 at 2.8ghz and a GeForce 7900GS with a 240W Shuttle power, so power draw shouldn't be a concern.
With an AGP 8x slot, you've actually still got a lot of options - although they are clearly overpriced vs the same card in PCI-E. What is your price range? If you can afford it, a GeForce 7800GS is a good option. An AGP GeForce 7600GS is a LOT less capable, but also a LOT cheaper.
It all depends on your budget. If you want something under $100, then the 6600GT is a good bet. For around $100, a used 6800GT or Ultra would be best, and if you can't find one then a 7600GS is the next best option. Any one of those cards will be enough to play WoW much faster than your current card.
I'm looking to stay under $100. I'm definitely going for a used card, so I should be able to score a better card vs buying retail. Also, I'd be willing o spend a bit more if I can get something significatly more quiet.
EDIT: Won't a 7800GS be too long for a shuttle case?
7600gt seems to be about the power you need. Throw on an NV silencer cooler...
The 6800 level cards arn't really... well... quiet at all.
I have a 220 watt PCU, will it be enough to power the 7600GT? The NV silencer will not fit. Will it be cool/quiet enough in my set-up?
EDIT: found this card in FS section: http://www.hardforum.com/showthread.php?t=1111574&highlight=9600+pro
Will this cut it or am I better of going the 7900GS route?
The X1600Pro is a pretty weak card. The 7600GT is great, however there aren't any below $100 and I doubt you'll find any used for that low. At that price point, a 6800GT is pretty much the best nVidia card you can get.
Which card runs cooler and faster, the 6600GT/6800GT vs 7600GS?
7600GS, by far. Only 27W under load. Compare that to nearly 48W on the 6600GT and 55W on the 6800GT.
(Granted, that's for the PCI-E version. The extra chip needed to drop the card down to AGP will need more power, of course.)
In PCI-E flavor, you can even pick up a 7600GS with a single-slot passive cooler. (EDIT: Interesting. Looks like Gigabyte put out a 7600GS that is passively cooled in AGP format! Impressive.
(Regarding performance - check out this review, here. 6600GT isn't on it, but the 6800GS is. Basically same performance as the 6800GT, so you can see how the 7600GT stacks up, anyway. 7600GS is less capable, naturally.)
Sweet, looks like 7600GS takes the cake. If I can't find one on the boad, I'll go for a 6600GT. Worst case scenario, I'll end up with a 9600pro. Thanks guys!
Go camp out at Circuit City for BF lol. You might score one for $90.
