Cool PCIExpress card
Guldaen
Bad Trader
What I mean by Cool is temperature wise. I am going to be using it in a MicroATX case so I want a nice video card that does not produce much heat. I was looking at the ATI x1900's, xt xtx and so on, something that will be able to play World of Warcraft on max settings at high FPS. Something $350 and under would be great. Please post any suggestion or comments on this. Also, SLI/Crossfire is not needed, I will only ever have 1 card in this system
You could play WOW on an FX5200. If your concerned about performance, a 6600gt would do fine or an x1600 maybe. A default answer would be the 7600gt. WOW is not very demanding.
The X1900XT's are the hottest (temperature) cards going right now...they actually draw more power and run hotter than the 7950GX2. A 7600GT with a Zalman VF900 cooler sounds like it would be good for you..
7900GT with a zalman vf900 fits your needs PERFECTLY IMO
cheaper would be the 7600GT with the same :p although id go for the 7900GT as its a huge step up
1900xt ICEQ3 from HIS is what your looking for, look through a few of the posts about it in the ati forum
I have been looking at the 1900xt ICEQ3, but I have not found any for sale anywhere? Anyone know of anyone who sells them?
