Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
he comprado nuevo cool master V8. ¿Es suficiente con Core i7 980X @4 GHZ? Gracias.
I bought new Cooler Master V8. Is it sufficient for Core i7 980X @ 4 GHZ? Thank you.
I'd say barely/not really if you plan on having a 100% load on all threads a lot. I'm using a V8 on my 920 (in sig) @ 3.9 GHz right now and temps stay around 80°C-85°C at 100% load. I'm a big folder, so everything in my rig stays at full load 24/7. My ambient temps in my basement (where it's at) are around 80°F-85°F because my 3x GTX 285s are dumping a lot of heat into the small area all the time. I've tried re-applying thermal paste 4 times with different methods to try and get temps down too. I'm in the process of finding an H50 or H70 to replace it with right now. I would recommend the same (or some sort of WC setup) for a 980X @ 4 GHz+.
Though I did have another i7 920 C0 stepping before my current D0 and it kept it at 70°C-75°C at full load. I thought it was odd my D0 ran considerably hotter. Not sure what to speculate about that.
