Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
hi, got a small question,what is the max length of video card tht can be put into the case?
I am considering a gtx580 and some of the cards are 11 inches long.
From the pics i have seen it should be no problem but thought I would check
