Mar 22, 2017 #1 G groebuck 2[H]4U 2FA Joined Mar 9, 2000 Messages 2,689 Do you have to let this cure? I got some to do a delid and plan on putting it on my Ryzen as well (not delidding just between the Ryzen and Corsair H60). is there a cure time I have to let it sit or can I use it right away?
Mar 22, 2017 #2 D Deleted member 184142 Guest No cure time. It stays liquid, however after a few cycles it will "dry" or harden, it can make removing HS a PIA, using heat tends to help.
