Cool Chem Cyanopoxy
Proneax
http://www.coolchem.com/index.cfm?fuseaction=cyanopoxy
http://www.coolchem.com/coolworld/index.cfm?fuseaction=coolworld
A (fairly) new epoxy-like system that is supposed to permanently bond objects together so well that it's like they're one object.
First like has some info about the product, second link has more info and some demos.
Someone even cut and then re-bonded the fan belt on his Jeep and it's been running fine for 5k miles.
Seems like it would be awesome for mod projects
But I have a question... would it be suitable for fabricating a case ie bonding aluminum or acrylic sheets together?
I've found that over time the best way to bond anything is just by tapping a hole and using a screw. This case I just did was bonded with cement and I'm worried about it in the mail.
hmm...thats really interesting to say the least...to me however it looks like normal cynoacrylic (super glue) with a spray accelerator...3m makes some. but then this guy pulling on this shit with out the bond breaking...well its interesting
