Cool case mods/addons
kevineugenius
I was actually shopping for a floppy ribbon cable in a local store when I came across this lovely gadget. http://www.newegg.com/Product/Product.asp?Item=N82E16813998805 It has a remote power-on and reset keyfob, and I just found it to be really cool, so I bought it. I'm just wondering, what other cool devices are there that I'm not aware of? I'm thinking like LCD-backed programmable button controllers, reverse KVM switches (multipler monitors for one PC instead of multiple PCs on one monitor), a small LCD that you can use as a desktop extension or a winamp tray or email reader, etc etc.
One thing that is the coolest bay device I own. It does everything.. 4 port auto fan controller, displays ANY information you want about your computer, etc..
http://www.frozencpu.com/products/2...lack_525_Baybus_Blue_Text.html?tl=g34c141s301
Here's the rest of the VL system bay devices.
http://www.frozencpu.com/cat/l3/g34...-LCD_Multimedia_Displays-VLSystems-Page1.html
Top quality products IMO.
Oh, I have videos of mine working too.. lol. If you need a password, the password is "turbo" without the quotes.
http://s8.photobucket.com/albums/a1/wiretap25/?action=view&current=MVI_0532.flv
filthysanchez said:
you can put multiple monitors on one pc....
That's not exactly what I meant. I hate going back and forth in the software to switch from monitor to monitor, and I run my TV off of my computer so I have surround sound and DVD player that works well. Anyhoo, if you run a clone, you have to set up the TV to be the primary display, then change it back when you're done. All I really want is to do a quick resolution change, then push a button that swaps the signal from my monitor to my TV. I bought a switch once that said it would do it, but it didn't work. The drivebay drawer is pretty cool though. One other I've seen from Thermaltake is a cup holder and cigarette lighter. Not sure if they still make them; and I dont really think that a cup holder is a good idea on you computer.
