converting vhs to dvd..will this do it well?
mnewxcv
http://www.microcenter.com/single_product_results.phtml?product_id=0256491
basically looking for something easy to use to convert these home movies before they deteriorate any further. I want to put them on dvds and want the audio and video to be as good as on the tape at least. Will a standard 4-head vcr via composite video be good enough too?
also, what brand dvds are good? I have a newer dvd player, is dvd+r or dvd-r preferred?
thanks
What I do right now is I have my Comcast DVR hooked up to a DVD player/burner and record the DVR movies directly to the DVD player/recorder ... and the results are quite satisfactory.
Now I know that the DVR is different then the VHS player ... but same basic principle applies.
Although, I suppose in thinking about this as I am writing ... it would be best if you can get a VHS player that has composite video out and even a digital audio out to ensure the best transfer (if they even make such a thing).
I haven't used that S/W. I used the DVD Xpress DX2 from ADS.
I also had a lot of 8mm and super 8 film. I sent that to an outfit in GA which converted it to DVD for me.
