Converting Thermaltake Bigwater
therapist
I have a Thermaltake Bigwater in which the pump died and I bought a new pump with 3/8" id fittings. I was wondering if anyone knew of a place to get the replacement fitting for the block. I know I can get adapters that will convert 1/4" to 3/8" but that kind of defeats the purpose.
Sharka thinks that it uses an 1/8" bsp connector. I contacted Thermaltake and they said that the fitting weren't available for another 6-8 weeks.
Thanks.
Well since Sharka carries Thermaltake Bigwater kits and has a few of them on the shelf right now. So what is your question? Ask Wes for the fitting you want. He has compression and barbed 3/8" fittings with 1/8 BSPP threads on it either in stock or due in Friday.
I was wondering if A. Any confirmation if they are 1/8" BSP fittings (the email I got from Sharka sounded like they were unsure." I would hate to order them and have them be the wrong fittings. B. If there were anyplace I can get the right fitting.
I wasn't sure if Sharka had them or not since they aren't on the website.
Thank you again.
