first off thanks for any input or help. my friend is a working mom of two jobs and needs to cut some costs if possible. so i want to help her, and i come to the horde's hive mind to see what the guru's suggest.i dunno her budget but im gonna say $100-$200 max, the cheaper and still watchable the better. they have 4 kids. tvs for 3 kids rooms and the living room i think is the plan. possibly a 5th for their bedroom.
my friend wants to cut her dish service, and hook up the converter boxes. she is on a budget for one. two she asked me for help, but ive never done this for one. and two ive not found all the information i need to inform her all in one spot.
so the question is to eliminate pay service, what is needed to pull a signal now? just a converter box and antennae per tv?
i think all of her tv's are still the old tube designs. my friend thinks if there was a roof mounted antennae then that would eliminate the need for one for each tv. however since i have no idea i came here to ask the horde.
I told her maybe try one box setup to see if its liveable before buying hardware for all the tv's in the house. ive seen used ones on ebay for $10-$20 and i seen this one new at compusa for $27
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=4164499&CatId=4039
