Convert to RAID0 w/out losing game data?
OldShoe
Installed 2nd hard drive. Have Modern Warfare 2 & other games via Steam download in first, original drive.
Initial attempt at RAID0 via CMOS failed. Restored computer from image backup (external hard drive).
About to launch 2nd RAID0 attempt.
Here's what I think I know (PLEASE correct me if I'm wrong):
1) First step is to setup RAID0 on CMOS. Choosing Marvell option to get 6gb/s speed.
2) That, I'm told, effectively formats both HDs.
After above steps OS tried to load but instead went to
"What Do You Want To Load?"
"Windows Setup (EMS" - Tried it. Got to default Win screen background only then it stopped.
"Windows 32-bit recovery (EMS)" - Skipped this.
"Windows 64-bit recovery (EMS)" - Tried it. Found a week-old image (newest) loaded it.
Effectively back to square negative seven.
All else having failed, read MB instruction manual (obviously written during Vista era) and copied Marvel win64 & SBxxxW7 drivers to USB. Something about loading driver(s) during a clean OS install? Could not get to a clean install :(
Now what?
Gigabyte XTA790-UD4
Phenom II X4 (Black Ed) 3.2GHz
8GB RAM
Win7 Ultimate
1TB WD Caviar 6gb/s (old)
1TB Seagate Barracuda 3gb/s (new)
Assistance appreciated.
(btw where you say CMOS you mean BIOS)
secondly, you will not be able to take advantage of the SATA 3 interface unless all hard drives in the RAID are SATA3. it will revert back to SATA2 speeds for both drives, which shouldnt make a difference anyway because they are both physical disks and cant read nearly fast enough to matter.
third- with fakeRAID (on-motherboard crappy RAID controller) you normally wont be able to extend a single disk to a RAID0 without doing a complete format. after you do that and build the array, you install windows like you normally would onto it. windows 7 will see it as a single 1TB disk in the install menu. windows XP will probably need drivers loaded from floppy (F6).
why not? insert windows disk and boot from it.
"Windows Setup (EMS)" - Tried it. Got to default Win screen background only then it stopped.
