Convert single disk to raid 0?
Kanaric
Usually when I want to do raid 0 i simply reformat, however this time I do not want to have to do this. Can I take a single drive and use a MB raid (on asus workstation mb) so that it takes the data on the one drive and stripes it across the two drives rather than reformatting? This would also be for a boot drive with Windows 7.
You'll need to reformat.
Use Acronis or Clonezilla to image your drive first, format/create the array and then restore the image on the array.
If you have windows 7 it can create a disk image for you, you do not need a 3rd party tool.
1. Create a disk image and store it on another drive (hopefully you have a large enough external drive or something)
2. reconfigure your drives
3. pop in the windows 7 cd, reboot, and restore the disk image from the installer
